Howdy guys, I’m trying to map my custom gamepad’s left and right analog sticks to a standard controller’s left and right analog sticks. I’m trying this by setting the following:
Cursor X → Left Stick X
Cursor Y → Left Stick Y
Right Stick X → Right Stick X
Right Stick Y → Right Stick Y
The result is that the right stick values are mapped, but the left stick values are not. Not sure why, because under the monitor tab the left stick values show up as cursors so I’m sure they’re being properly assigned. In fact, I clicked add mapping for all 4 inputs from the monitor tab, so I’m not sure where the input/output is getting lost.
Figured out why; my device (Teensy) was presenting itself as a USB keyboard + mouse + joystick. When I changed the configuration to present itself only as a joystick (gamepad) it started working as expected. Still not sure why though, as I didn’t change any of the mappings, so maybe HID Remapper was just getting confused due to the presence of the keyboard + mouse?
Mouse X/Y uses the same code for the inputs as the left stick and HID Remapper keeps track of whether the input is absolute (stick) or relative (mouse). When both are present on the same device it marks it as relative which breaks the stick inputs.
It should be more granular about it but for now at least it’s how it works.
