Hi JFedor, The Mavercade Dongle is not recognizing Logitech MX Revolution (Model M-RCL124) when plugged in to USB A port. On the remapper.org website under “Events” it shows no messages. Is this mouse incompatible with the Mavercade Dongle. Here is the link to the mouse. It comes with a bluetooth USB A stick that works on the laptop but not when it is plugged in to the Mavercade dongle. I just purchased the dongle and was asked to get help here.
One thing that would make it incompatible with this particular variant of HID Remapper is if it’s a Low Speed USB device. They’re rare these days but if it’s an older device it’s possible.
You could check with this utility:
The mouse works perfectly when plugged in directly to the newest MacBook Pro or a Windows 11 laptop via USB port. Both laptops recognize the MAVERCADE dongle and I can pair it through the Remaper.org website, however when I plug in this mouse or a different wired USB mouse, which is a newer one it does not recognize both of those mice and I cannot move those mice on the screen. I did put a paper clip into the little hole on that dongle to reset the firmware and then I flashed it with a new firmware available through your GitHub page however, it’s still the same. Both mice are still not being recognized and there are no keys that are showing up as mapped. What am I doing wrong here? Why isn’t the Mavercade dongle recognizing both the wireless and the wired mouse when plugged into the USB A port? Could you please assist? Do I need to update the firmware and if so, where do I update it from or what am I doing wrong?
I don’t know. I told you what you can check.
(On a Mac it’s even easier, hold Option, click the Apple menu, then System Information → Hardware → USB, then select the device.)
what do I do after selecting the device? This is not really helpful as I’ve already mentioned both the wired and the wireless mouses are not being recognized when plugged into the MAVERCADE dongle. Is there a new firmware that I need to update too? Is there any setting within the Remapper.org which need to be modified for the mouse to be recognized?
You check what it says under “Speed”.
Speed is listed as 12Mbps for both the mavercade dongle and the Logitech BT mini receiver (my mouse that mavercade is not picking up).
What do I do now? How do I get this to work? It’s not even working with the other wired USB mouse as mentioned.Please advise.
Also, I’ve asked you multiple times what firmware from your GitHub page needs to be flashed on the dongle. could you please advise?
Here is the MAVERCADEdongle “HID Remapper” I have bought.
12 mbps is Full Speed so that’s not the issue.
For firmware you should be using remapper_board.uf2 from either the latest release or the latest pre-release. I wouldn’t expect a difference for this board, but at this point try both.
I would try to find a device that works. Specific devices may have some incompatibilities, but if no device works then maybe something’s wrong with your HID Remapper unit.
