Hello
I am using Adafruit feather RP2040 plus Magic Boots S5 to play Tekken 8. It works well but after a short time suddenly freezes and then requires a reset on the Adafruit to play again (or plugging in again).
Regards,
Sohaib
Hello
Regards,
Sohaib
I don’t think the S5 works for this. You’re likely just experiencing the same 8 minute timeout you’d get with no auth device.
The disconnect takes place randomly sometimes after a few minutes sometimes longer or shorter. What should I use instead of the S5?
MagicBoots PS4 (v1.1), Haute42 Booter5, PXN N5 are some dongles that work. You can also use any licensed PS4 arcade stick and some other controllers like steering wheels.
