How do I get SHIFT function on Catch 22 (PS5 interface)?
Johan
Johan
Not sure if that’s what you mean but if you want buttons to have a secondary function when another button is held (or for it to be toggled) then you can use the Layers mechanism for that. Set some button to activate a layer (with the sticky flag set or not depending on what you want) and then you can have separate mappings for other buttons on Layer 0 and on Layer 1.
https://www.remapper.org/manual/#layers
Other then that maybe @OneSwitch can chime in if “shift” means something specific in the default CATCH 22 configuration.
I got this from @OneSwitch. If SHIFT just through the Catch 22 (HID Remapper V6) you’ll need updated JSON. Post on the HID Remapper Jack forum.
But I dont understand it.
